It is currently Fri Aug 15, 2025 2:18 am
Post new topic Reply to topic  [ 75 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: I hate go bars.
PostPosted: Fri Dec 19, 2014 1:18 pm
kencierp wrote:
http://kennethmichaelguitars.com/vacuumclamp.html
Thanks for sharing Ken, very nice simple design!
PostPosted: Fri Dec 19, 2014 1:26 pm
Braces do not move or skate in our vacuum press -- the tape is simply used to hold place while layout the braces. And this of course is the point of using a vacuum press in the first place. Now I have been told, actually by a tech from the Taylor factory, that the vacuum press has the added benefit of drawing off water quickly and speeding drying time as well. Seems logical to me.
Ken Cierp
These users thanked the author kencierp for the post: Michaeldc (Sat Dec 20, 2014 6:55 pm)
PostPosted: Fri Dec 19, 2014 1:32 pm
I have only had one or two go-bars get away from me. Rubber tips may be one thing that keeps them in place. Someone here once suggested putting a piece of carpet on the upper deck to keep them from sliding on that end.
PostPosted: Fri Dec 19, 2014 1:37 pm
Last Name: Sollod
I constructed a simple (crude) vacuum system that I use only for bracing. I constructed a wood frame, got some clear plastic from the fabric store (Jo-Ann's as I recall), and glued the plastic around the frame. I placed weather stripping around the frame (on top of the plastic) so that it would seal around the edge of a radius disk. I had sealed the radius disks with Z-poxy so the weather stripping seals against it well. I bought a valve from joe woodworker that fits into the plastic sheeting to attach the vacuum pump to. The vacuum pump was purchased from ebay used for about $50. I clamp the frame to the radius dish after placing the top or back inside and turn on the pump. I run the pump continuously during glue up. It may be crude but it works quite well... and saves space in my small shop. I don't have a picture to share right now...
www.swiftcreekguitars.com
PostPosted: Fri Dec 19, 2014 1:53 pm
First name: Rusty
Before you give up on go bars consider tacking a piece of carpet to the slick gobar deck ceiling. Use a piece of old door mat to give a little friction to the bars and they won't be prone to go slipping.
PostPosted: Fri Dec 19, 2014 2:47 pm
Thanks for all the great input folks!
PostPosted: Fri Dec 19, 2014 2:54 pm
Kenneth,
Yours looks like a very simple, economical set up. I'm a bit confused though. Do you just drop it over a radius dish? What does the top rest on?
PostPosted: Fri Dec 19, 2014 3:11 pm
For those of you rocking the joe woodworker pump, is it noisy?
PostPosted: Fri Dec 19, 2014 3:42 pm
You guys used vacuum with hide glue?
These users thanked the author Terence Kennedy for the post: Al Pepling (Sat Dec 20, 2014 10:50 am)
PostPosted: Fri Dec 19, 2014 3:52 pm
Ed,
Yes you could construct it in such a way to do that, but I prefer individual contoured cauls under each brace. The ones (braces) that are flat on the glue surface do lay flat and therefore do not get distorted or cause distortion.
Ken Cierp
PostPosted: Fri Dec 19, 2014 4:01 pm
Interesting I use all radiused braces, so I should have any even easier time.
Hmm, now y'all got me thinkins...
PostPosted: Fri Dec 19, 2014 11:51 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
I have the Excel 1 and while not completely silent , I hardly notice it when I'm working.
"I've been had again"
Tim Benware
Creedmoor, NC
PostPosted: Fri Dec 19, 2014 11:52 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Not me I can't glue it up that fast. When using hide glue I go to my Go-bar deck.
Tim Benware
Creedmoor, NC
PostPosted: Sat Dec 20, 2014 1:30 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
WaddyThomson wrote:
I use CPVC with a spring inserted, and a dowel. 7 lbs. of pressure. Works well for me.
I have experience with vacuum systems (they have their points), and various go-bars. I've settled on a system like Waddy's. I won't go back.
PostPosted: Sat Dec 20, 2014 1:33 am
Go bar.2 eh?
These users thanked the author meddlingfool for the post: jeb98 (Wed Dec 24, 2014 11:07 am)
 Post subject: I hate go bars.
PostPosted: Sat Dec 20, 2014 11:10 am
City: Tyler
Well I've picked up some great tips on go bars. Stops - why didn't I ever think of that! One thing I have noticed on some pics of go bars in use is that some folks put way too much bend in them. IMO there is plenty of pressure without bending them much. I've never had a problem with them springing out or slipping.
PostPosted: Sat Dec 20, 2014 11:16 am
I did not read everything, so maybe this is redundant. I have seen go bars that are spring loaded, telescoping. Do those have any advantage?
PostPosted: Sat Dec 20, 2014 11:23 am
You need to read everything!
PostPosted: Sat Dec 20, 2014 11:34 am
Regarding how much pressure go-bars produce based on the degree of deflection here is a bit of a study that I did years ago. The results are not what some might expect.
Note the amount of deflection below:
And the resulting clamping force:
A bit more deflection:
The most deflection:
And what it gets us in clamping force:
Ain't physics great..... ;)
These users thanked the author Hesh for the post (total 2): Lonnie J Barber (Sat Dec 20, 2014 9:57 pm) • Michaeldc (Sat Dec 20, 2014 7:06 pm)
PostPosted: Sat Dec 20, 2014 11:40 am
And ya know if you bend em more it takes more force so where does that go? Sideways! I think that's the biggest mistake I've seen other luthiers make.
I set my deck for a deflection of about 1" for my 24" bars. I've had em slip off of a brace top but they don't go shooting out anywhere.
PostPosted: Sat Dec 20, 2014 11:54 am
First name: George
City: Seattle
Yeah, just a little flex is all you need. Easier to place and less risk of drama.
I do as Michael Colbert and temporarily key braces in place and use scrap to span them. I find this to be an effective method of keeping them in place while I quickly and safely apply even pressure.
I'm with Terence regarding the hot hide glue. I like to use it on braces and really can't see how I would do so if I were to employ a vacuum system. I'm not saying it can't be done, or that not using HHG makes an inferior instrument. It's just not how I do it.
George :-)
PostPosted: Sat Dec 20, 2014 12:44 pm
HHG's very short open time is what stopped me from going the vacuum clamping route as well that along with the noise of the pump reminding me of.... well I won't go there. :?
You can extend the open time of HHG by using a "hot room" which is something that the violin folks are very familiar with. It could be a small room or closet that you bring up to say 110F or so.
No issues here with positioning or placement of the bars causing skating because of HHG's quality to tack stuff in place quickly.
Not having read the entire thread so forgive me please if this has been mentioned but back in the day on the OLF Howard Klepper used to remind folks to wear eye protection when using go-bars - always a good idea too!
Rusty's post about lining the top of your go-bar deck with something abrasive to help keep the bars in place - another great idea that I have yet to get around to.
PostPosted: Sat Dec 20, 2014 6:28 pm
Last Name: Beaver
City: Lake Forest
Vacuum systems are a popular way of getting it done, but, when I do the math and see they can only generate up to maybe 14 psi I shy away. I'm a titebond user and am always looking for 100-150 psi.
Joe Beaver
Maker of Sawdust
PostPosted: Sat Dec 20, 2014 6:37 pm
But not for guitar bracing, right?
PostPosted: Sat Dec 20, 2014 7:11 pm
Friederich shows an interesting jig for gluing braces in the Courtnall book. More compact than a go bar deck and less complex than a vacuum system.
Users browsing this forum: Bing [Bot] and 18 guests
